petnzoo wrote:
Firstly...I am new to all of this. My first camper. I'm a little older, and retired, and hoping I can do this. My camper is in the middle of being worked on. I've never towed before. So..I see from previous posts, weight capacities and such are required. I'll have to get those later. My question is..do I need a stabilizer bar, or weight distribution? And in laymen terms, how do they work? What I can tell you.. My TT is a 1987 Shasta 155MB. (15 ft). Specs say 2280 pounds.
My tow vehicle is a 2008 Honda Ridgeline with after-market reese hitch.. I've heard several different things. I want not to get sway, if avoidable. Can anyone help me understand what I may or may not need? Thanks in advance..
Welcome to the forum.
With a Ridgeline I would say that you would need a WDH and also a way to control sway. There are many WDH systems that have anti sway built in and the one in my signature is one of them.
In layman's terms they work like this:
WDH - There are sping bars that are an integral part of this system so that when sized and installed properly, they take the rear end sag out of the rear of the truck after the trailer is connected. The weight is re-distributed forward to the front axle of the truck and aft to the axle of the trailer, flattening out the hinge point (the hitch).
Anti-sway - Any anti sway device would involve some measure of resistance (friction or dashpots) to counter trailer sway, which is a "fish-tailing" of the trailer as it is being towed. With resistance countering this motion, the motion is "damped" and the trailer tows true (straight)
Before you can get the proper sized hitch system and before installing any anti-sway device (built-in or separate) you need to get the trailer and truck weighed on truck scales. That is a topic for a separate thread.
What you need to know is the percentage of weight that is at the hitch and the total fully loaded weight of the trailer. The hithc weight should be between 10 - 15% (or more) for a good balance to minimize sway. This should be ensured BEFORE you install any anti-sway device.
You also need to ensure that the total loaded weight is not exceeding any capacities (tow capacity, rear axle capacity) of the truck.
If all of that is taken care of then you are good to go!
Good luck.
