mdamerell
Feb 08, 2015Explorer
Need to look in your manual. I believe the standard Ford hitch is a Class 4 which means above 850# tongue weight (diesel SRW) you need a WD hitch. The one source I had listed 1,400# max with WD and you need to read all the fine print. Don't have the "official sheet" on your truck, you did not say but I'm guessing a 2015? In you manual it should list if you need one or not based on tongue weight and the actual hitch class. You probably will still want some sway control.
Others are probably more knowledgeable than I on pulling TT's.
44,056 PostsLatest Activity: Jan 12, 2020
