2oldman wrote:
Your experienced friend should take up another subject.
As you can see, the group here has the knowledge and many have gained that by coming here and asking for help and information. Just a suggestion, here. Go fishing, or watch a game with your buddy, but come here for Truck Camper advice.
Everyone sharing about a charge controller will correct any issues of overcharging your batteries, is giving you sage advice. Much like a spillway does for a dam. When too much "Power" comes down the cable, it diverts this from reaching your batteries. These are "spikes" that occur when Clouds come between the sun and your solar panels. The panels go down in collection and then "spike" when the cloud moves on. This is one of the reasons you have a charge controller and hopefully Catastrophic fuses at your battery bank and an additional one for your inverter. Solar collection is much like a Roller Coaster Ride throughout the Solar Collecting day. That is one of the reasons you don't want to connect your solar batteries directly to the battery terminals with alligator clips. Also, only get a charge controller that can be adjusted for the type of your battery, Temperature Control and if possible programmable for the size of your battery bank.
Do you have your battery bank set with the converter interrupted when solar charging?
As for longevity, you will KILL your first set of batteries learning this process of solar, use and storage. So, be prepared for this as you increase your learning curve of discharging limits, charging % and temperature compensation, then through in Bulk, Absorb and Float Charges as well as the time in mode depending when and length of the previous day's charging cycle.
As for longevity. Batteries life are dependent on cycles. Use them or they will die. Use them a lot and they will die sooner. Monitor and use your batteries properly for this optimum design parameter and they will exceed your expectation in life and value to you.
As others have suggested, go do an inventory of what you actually have and where everything is located within your truck camper.
What are the Solar Panels you have? (Mon or Poly)
How are they wired? (Parallel or Series)
What type/size cables do you have? (4ga-6ga-8ga-12ga-14ga)
Do you have interrupter Switches? (Breakers before and after Charge Controller and inverter)
Do you have Catastrophic Fuses rated for your Battery Bank? Inverter?
What type of Batteries do you have? (FWC-AGM-LiO)
Do you have a maintenance plan for battery bank, if needed? (H2O-Equalizing)
Do you have a battery charger modern enough to cycle the batteries through Bulk/Absorb/Float so as not to “Cook” your batteries during periods you fall below 50-55% minimum discharge rate determined by battery type?
By all means, have a great time with your new truck camper and something I am passionate about, instruct and write about; Solar. Solar can be a life changer for how you enjoy your time in your camper and might just migrate to your own home. Me, I full Time (as I have no place to return to) and have lived entirely off the grid (only solar) for more than 7 years with 1,860 watts of solar (13 panels) and 1,460AmpH of batteries, traveling the west in a truck camper.
Welcome to the TC forum, too!
b
Edit: Double Post
