penguin149
Sep 25, 2022Explorer
Pbutler97 wrote:
If you know what you're looking at, and crawl under most travel trailers that were built in the last 10 years or so and are on a Lippert frame, you might have second thoughts before you jack it up to change a tire let alone jacking the entire thing up off the ground to level it.
My thoughts as well! TT frames seem to be the thinnest possible to reduce weight and allow for more vehicles to be used as TV's. Leveling jacks would test frame strength and probably not turn out well! Same reason adding a lot of weight to the rear bumper scares me.
