p38fln
Oct 07, 2022Explorer
We have a friend with a 1984 Coachmen 32 foot travel trailer. It's virtually identical to our 1991 Citation 32 foot travel trailer. The Coachmen was obviously a higher class unit when new, his has leveling jacks at all 4 corners along with a built in analog clock and water tank sensors, while the Citation...has absolutely nothing. I level the Citation by putting jack stands under the frame between the rear axle and last crossmember before the bumper, lowering the nose jack, raising the jack stands, then raise the nose jack back up. I'm not trying to get the wheels off the ground just make the bathtub drain properly and keep the thing from bouncing everywhere when someone walks through the bedroom.
We had a 1991 Starcraft Starburst popup trailer before the Citation and its built in stabilizers could only be used to 'level' the trailer by messing with the nose jack as well. In that Starburst's case, if you didn't put some tension on the stabilizer jacks the door wouldn't stay shut and the single axle trailer would get extremely bouncy if someone got in one of the bunks without getting the jacks SOLIDLY on the ground.
FYI - He said only one leveling jack still works and he uses a bottle jack and a bunch of wood to level it.
