- hedgehopperExplorerIf the truck is sitting on a level surface I don't bother. If it's on a slope, I usually grab a rock and put it against the downhill side of one of the tires.
- Fisher_BillExplorerAlways and every time.
If the wife and I are sleeping in it I will be sure it will not go anywhere even if I get bumped by another rig.
Kind of like not wearing a pfd until you think you need it when in reality I think it better to be prepared for every event so when we cross the bar pfd's are worn, rig gets chocked like a firetruck no matter what. - SidecarFlipExplorer IIIMy emergency brake is disconnected, cables froze up and I'm too lazy to fix it.
- Reddog1Explorer III do not chock my wheels
Eric&Lisa wrote:
That is the procedure my truck's Operator manual says to use. When I am ready to leave, after starting the tru?k and holding the foot brake, I take it out of Park before releasing the Parking brake. That prevents a preload on the transmission.
Foot on brake. Truck in neutral. Set parking brake. Release foot brake. Allow parking brake to take the load. Place transmission in park. No load on transmission to hold the vehicle.Eric&Lisa wrote:
I agree with this method with my 4x4 truck.
Optional if I am concerned about the holding between the rear wheels and the ground. Place truck in 4x4. This ties the front and rear wheels to each other through the transfer case. The rear wheels are locked because of the parking brake, and the front wheels are also immobilized because they are tied to the rear wheels.
It would have to be a pretty steep hill to chock the wheels of the truck - and would not be a hill I would camp on.Eric&Lisa wrote:
I think most if not all automatics are designed in such away the do not pump transmission fluid through the cooler when in reverse. Due to this, the fluid gets pretty hot if in reverse for long periods of time. Without a transmission temp gage, we can easily burn the fluid which in turn will shorten the life of the transmission. I had a gage on my previous truck, and will soon have one on this truck.
And while I am at it....
I always place the truck in 4x4 low and drive *forward* on to the blocks. Never back on to the blocks. The reverse gear is a higher ratio than 1st gear forward. It seems to 'build a lot of power' trying to back on to the blocks, but that is just the torque converter slipping the RPMs. That creates a huge amount of heat, especially after the truck has just been driven a long distance hauling the camper. Putting the camper on blocks would be just before shutting it off and setting up camp....after all that heat was built up in the transmission...allowing it to now heat soak for hours. Not good for its longevity!
-Eric
If you do a lot of backing up, it cools the transmission if you put it in neutral and idle the engine for a few minutes. If you are in stop and go traffic, placing your transmission in neutral while you are stopped will also help to cool the transmission. - srschangNomadNever thought about it, and no, I don't see any need to chock the wheels.
- RubiranchExplorerNo. :D
- Wagonqueen_TrucExplorerI know I really don't need to chock, but I do anyways. Ease of mind.
- TiziExplorerI don't chock them. I use my parking brake.
- SidecarFlipExplorer IIIThe only thing I chock is my small square hay baler (NH 575) when I swing it out to run it...... Use a nice Copperloy Alloy chock.
- Eric_LisaExplorer IIFoot on brake. Truck in neutral. Set parking brake. Release foot brake. Allow parking brake to take the load. Place transmission in park. No load on transmission to hold the vehicle.
-Eric
