yankeeslover's avatar
yankeeslover
do you keep water in holding tank between trips?
we go camping every other weekend. we only use sites that are full hookups so we don't camp using the holding tank. I did santitze the system though when I purchased the new camper last month. we went camping last weekend and used the full hookup water.. now my camper is parked in my driveway with no water in the holding tank but I believe still water in the lines from our last trip. I will go camping again next weekend to a full hookup site. its been 90 degrees here for past two weeks, how do I know that the water in the waterlines is still good? i would hate to santatize the water every couple weeks. the city water at my house is cholronated which was why i was thinking of filling it between trips so that chlorine water stays in the lines.. but how does others do it between trips? like i said, the tank is dry right now but probably still some water left in lines because i didn't drain the lines, when i get to campground should i just let the water run for awhile to get the old water out of the lines? or is two weeks not enough time to turn the little water that there is in the lines bad? thanks again
  • Just run the system for a while when you get to the next campground.
  • I always leave my water tank 1/2 full , drain it when I get home and refil with city water . My grey and black tanks get flushed when I get home ( have my own cleanout to the sewer) And then I add about 5 gallons to each after they have been flushed , So on my next trip it keeps things loose in the holding tanks , and I have fresh water in my supply tank if necessary.
  • Give it a taste sometime. Best way to find out if the tank will hold up all summer. Ours does.
