finsruskw
Aug 02, 2016Explorer
You are already gonna be most of the way centered while backing under the TC when you are between the wheel wells. That is unless you have it raised up way to high and above them to begin with.
The centering blocks only come into play in the last few inches of back up. If you fear being off enough to screw up the jacks , chances are you are gonna hit the wheel wells not to mention the outer edge of the fenders in the case of a dually There is enough slop in my jacks for at least a couple inches wiggle/wobble room when at 2" or 3 " above the bed while backing under it.
Just be carefull and you will be fine. Use the "GOAL" Method.... Get Out And Look often.
44,065 PostsLatest Activity: Apr 13, 2026
