Reality_Check
Aug 03, 2016Nomad II
JimK-NY wrote:mkirsch wrote:I have seen a description of V shaped blocks to guide the camper into position. I would think twice about using something like that. The jacks and brackets are not designed to have a strong force pushing sideways. I would be concerned about tearing the brackets from the camper or bending the brackets or jacks.
We're only talking about an inch of movement, at most. My camper will easily "wiggle" an inch in any direction sitting on the jacks.
Please explain this "wiggle" business. I notice a very little wiggle when the camper is raised really high. Mostly I notice some movement if I do not lower all the jacks at exactly the same rate.
What wiggles? My jacks don't seem to bend, flex, or wiggle. Certainly the brackets don't bend, flex or wiggle. Nor do the sides of my camper. I would guess you are bending the wooden frame of your camper. That may not be a great idea.
So they mean sway... don't let semantics get in the way.
Campers sway/wiggle/move. Steel moves, flexes, bends. Parts give and slop back and forth. Give the designers credit, these things can take quite a bit of juggling/swaying/bumping/wiggling without any damage. As stated; push on a camper that's up in the air...it "moves" a lot.
I'm sure some would shudder watching me slide into ours. Get it close and ram it home. I have zero clearance between my rails on the bed and the plates added on the camper; steel on steel as it slides into position. Without a doubt, I'm never as lined up as perfect can be which translates to pushing it one way or the other regardless. 20/30+ loads and unloads a year and I'm fairly confident it's all still good.
44,065 PostsLatest Activity: Apr 12, 2026
