I have a 2002 F250. The Cruise Control recently quit. I checked the fuses, there isn't one for cruise control and I don't find anything else that may possibly be on the same circuit that doesn't work....
The recall will look different depending on weather or not the switch was leaking at the time the recall was done. If it wasn't leaking there will be a big jumper harness with a fuse in it. The switch will have the same connector on it as the connector on the harness. It it was leaking the switch will have a different connector on it and the jumper harness will be very short with no fuse just to go from the origional connector to the new one. Any switch you get now will be updated.
