kohldad wrote:
Already know my new truck will be a 2014 Dodge SRW Crew Cab 4x4 with auto tranny. What I don't know is if I should go with the new 6.4 or diesel. Worked outthe numbers and the cost for my use of 15k miles/year with 50% TC duty, 25% DD, and 25% errands is only a few hundred difference a year.
So it comes down to the other advantage to decide.
Diesel - all the power and torque could need and then some.
Gas
-no cool down time (important due to lots of stops for sightseeing)
-less weight on the same axles/brakes equals better braking (best I can find, the 6.4 will use the same axles as the diesel)
-less to worry about (no DEF, turbo, etc)
My previous truck was a 92 F350 w/460 auto which I used to pull a 7,000# TT including a trip to Yellowstone and Arches. Never had an issue with power on that truck. So am familiar and comfortable with reving the engine for the power.
Which would you choose and why?
You must remember if you get a gas engine they will look funny at you when you pull in at night in a new camp ground, there will be no lawn chair set out for you. Then on the good side of it, your pickup will not smoke, shake, smell, make all that noise, your fuel will cost 70 cents per gal less than diesel, and not tract on your carpet, diesel repairs are double, and the guy down the street will tell all the neighors you don't understand the power you lost.
