intravino wrote:
If you found a low mile, good condition 20 year old Cummins dually in Quebec, buy it.
95% chance whatever holes you’re trying to describe won’t matter.
100% chance it will be better than 95% of the rest of the old trucks you’ll find up there.
Don’t worry about it.
Unfortunately, it is not a Cummings, it is a gasser V10.
Also, it is not in good condition, the front fender are damaged near the lower part and the cab corners are perforated. I got quoted bettwen $4 and $5 gran for a repair. Too bad, the engine is top notch and the ATX is ok.
99, 2000, doesn't matter, same truck basically. The V10 is a good engine and that combo obviously has enough snort to haul a TC easily.
I presume it's for sale for a very reasonable price. It's not worth fixing rust, holes and body damage though. In great condition, no rust, that truck is worth $10k usd, tops.
If you can get it cheap and it runs well, it sounds like a good camper hauler. If it's more than $8k CDN, I'd pass. Just because it runs well, an owner that doesn't take care of the truck cosmetically, is much less likely to have taken care of it mechanically. And remember, everything you need to repair on the underside will be a rusted mess, stuck bolts, etc.
