AH64ID
Jul 16, 2014Explorer
hertfordnc wrote:
This is interesting. I beleive my gague is very accurate. I had a and android app picking up the temp off the ODB and it matched the analog gauge. I have not hooked it up for htis problem.
I understand from the cummins forum that I might have a 200 degree thermostat?
My hunch is the water pump. I am hearing a sqeeak from something on the serpeintine belt, the truck has 205,000 miles so it's about due, I'll check it tonight.
thanks
Someone would have had to swap that in, as 200° was not the stock temp. I would swap in a 190° just to be sure if you question in.
What temp does it run going down the road on a cold day?
The water pump might be squeaking, but it will still pump water since it's a metal pump.
