BenK
Jul 23, 2014Explorer
Made my own...
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25582580/gotomsg/25587464.cfm#25587464
You have found what I found out back in the 90's with my GMT400 Sub...the OEMs
no longer make much of anything anymore and outsource it.
Timken saw that and worked up these new hub assemblies to address this new direction
from their customers...the automotive OEMs
The hub/bearing/ABS sensor is all one these days on most vehicles and is to be
replaced as an assembly.
Even if you do find the individual part numbers, they can't be ordered as they
are not offered but as an assembly
Here is a clicky to one of my posts on these new hubs:
http://www.rv.net/forum/index.cfm/fuseac........d/23555087/gotomsg/23556377.cfm#23556377
The no radiator cap is for the OATs and HOATs. Mainly due to O2 (oxygen) getting
in there when you check fluid levels. Mainly due to the 'O' (organic protection
whatever it is) and the 'A' (acid to etch the metal clean for the 'O' to coat
and protect). Since not all the acid is used up in the initial fill, it is still
reactive to any O2 that gets in there. Toss in some dirt and you have another
chemistry process brewing in there.
Yours is HOATs (hybrid organic acid tech) and GM is OATs (organic
acid tech) and is for the 5yr/100K warranty. I don't like these and
went back to American Green on my GMT400 and will do so till American
Green is no longer available or become too expensive vs OATs/HOATs.
The old 'over flow' bottle is no more just an over flow, but is now pressurized
as part of the hot tank side of the radiator.
It is now the 'fill' access or remove the radiator hose and fill via that.
To check fluid level, you just view the fluid level through that bottle's translucent
plastic body.
Here is a clicky to my DIY reverse flush kit that is copied from buddies radiator/AC
shop's EPA mandated system. The only difference is that this DIY does NOT have
a recycling tank. You have to take that bucket to the recycling center
http://www.rv.net/forum/index.cfm/fuseac........d/25116820/gotomsg/25117737.cfm#25117737
Here is the image on the HOW2
agesilaus wrote:
OK I have been surprised this weekend by a couple discoveries on my F150 5.4 liter.
1) The front wheel bearing is pressed into the brake disk and sealed. I was going to replace them but the bearings seem to be special order unless you buy the disk with bearing installed. Should I replace them in the first place, and can I reset the new bearing with the block of wood and hammer method or do they have to be pressed in?
2) Second there is no radiator cap on this and no drain either. I was going to drain and replace the coolant but there doesn't seem to be a way. It seems to have a double radiator system too with about 4 inches in between.
I got a flush kit but with no cap I'm stumped on using it, can I just remove the overflow bottle cap and let it over flow there? How would you get rid of excess water then?
Thanks for any guidance in these matters.
plastic body.
