hertfordnc
Jul 23, 2014Explorer
ib516 wrote:
I was told by a factory trained diesel tech to remove the coolant hose that mounts to the nipple on the back passenger side of the block and attach a hose there. It flushed everything out of the lower rad hose, including some sand like particles. Pretty easy. The fitting I am talking about is visible in the picture. It's in photo left, at the back of the black valve cover, sticks straight up, kind of brass colored here:
That turned out to be the best tip ever. I had a small scrap of garden hose with the female end that fit snugly over the pipe. I clamped off the heater hose and connected a garden hose and ran the water with the cap off for a while, then i opened the drain and put the cap back on, then i closed the drain and opened up the heater hose, i ran each until they ran clear and removed lots more crud.
I am fairly certain there is no air trapped in the engine anywhere.
thanks
