No problems out of my 05 Cummins. I have owned it since new and it has been running well over 100 hp over stock since 08. The transmissions are good it just depends on how you treat them. I am embarrassed to say that I have never changed the fluid or adjusted the bands on mine. I am getting the famous shuttle shift with mine but I just shift it manually when this happens. I feel like when I make it to 100,000 (this will be this year)that I will have gotten the life out of it and then a bullet proofed trans is going in.
The key to the 48 is to keep the converter locked as much as possible. It will only lock in OD unless you run in tow haul. Then it will lock in 3rd also. Anytime I hook to something it is run in tow haul.
