jerem0621 wrote:
stro1965 wrote:
I have the Ram 20K (Curt) that fits right into the puck system. Awesome hitch. I'm thinking of selling it, but only because I'd feel better with a slider. No issues whatsoever.
You could add a slider base to your Curt 20K...but you may have to use a picture frame adaptor. The Slider Base on the Curt is very robust...using solid bar stock for the slider rails...lots of slider bases use tubes instead of solid bars.
Thanks!
Jeremiah
And Demco makes the best picture frame! Model 6099.
http://www.amazon.com/Demco-DEMCO-6099/dp/B00SQFKMUOUnlike the Reese/RAM picture from the Demco can be released without first unpinning and removing the hitch. I pick my setup as a single unit. Puck latches not yet installed in this pictire. In the earlier picture I posted you can see the short handle latches.
