It's the original clutch. No other symptoms. Driveline U joints were replaced a couple years ago.
Grit dog wrote:
HappyKayakers wrote:
I have the 6 speed manual. Vibration is at idle and while driving. Not bad now and it appears I have time to look at different options.
Mote wrote:
When does it vibrate? All the time ? If it's a manual transmission and the flywheel has hot spots that can cause a vibration on take off. If it's an automatic not sure how the flywheel will cause a vibration.
What clutch did you put in it last? How long ago?
Other symptoms?
Either way, it's much closer to a $2k job, WITH a good aftermarket clutch including installation.
