woodhog
Jul 28, 2015Explorer
It finally caught up with them, they put the first heavy diesel in a pickup back in the early nineties, mated it to the largest car transmission they had in the automatics, from then on it was failed transmissions for many years, early ball joint failure, sway bar end links broken,hub bearings failing, universal joints failing in the front end, universal joints failing in the drive shafts...it took them until the latest chassis design in 2012 to get the suspension right...
Quite the mess..
Quite the mess..
