Me_Again's avatar
Me_Again
Explorer III
Oct 14, 2013
Dodge Test Drive(s)
Well today was the day to do a couple test drives.
Back ground. We are currently on our second Dodge/Cummins.
We purchased a 1 or 2 year old 1993 Std Cab 4x4 Dodge/Cummins and drove and towed with it for around six or seven years.
In June of 2001 we purchased a new 2001.5 Std Cab 4x4 Dodge/Cummins 235HP/460TQ auto tranny truck.
In the summer of 2004 we upgraded from out 26' Terry 5th wheel to a 29' Cardinal 5th wheel. At 32K on the clock I had the 47RE transmission custom built for towing at DTT in BC, Canada, added stage one injectors, and a Edge Comp in timing only mode, DTT smart controller, replace the front half of me MagnaFlow SS 4" exhaust with a Banks 4" turbo mounted exhaust brake, Banks down tube and intermendiate pipe. Later came a PDR-35-12W turbo. At around 325HP and 650TQ at the rear wheels it tows our 12,400 pound trailer very well, delivering average fuel mileage of over 12MPG on long trips. The Dodge has 104K on the clock and is now broken in.
So today we drive 40 miles up to Bellingham to drive a 2006 Quad cab SLT Dodge/Cummins 4x4 with auto tranny. It had 78K on the clock and look fairly clean for 32+K, which I think is over priced. Long and short of it was DW and I did not think that it was that much quieter on the freeway than our noisy old 24V Cummins. AND my cuurent truck would most likely run circles around it. Between the sloppy tranny/torque converter and stock hp/tq, I was not that impressed.
So we leave the Honda dealer and cross the street and drive a block to the RAM dealer. Spend a lot of time talking to a couple nice guys Joe and Aldo, and then Aldo, DW and I take a 2013 Big Horn 4x4 LWB SRW 3500 400/850 with Aisin tranny for an extended 30 minute test drive.
So I now know that a 3rd gen is not in the cards for me for a couple reasons. One they all seem to be over priced, and maybe they sell for a lot less than what you see them listed at. And number two I do not want another 47/48RE that needs thousand of dollars in upgrades. And number three, I want a 2013 or newer!!!!! DEF me baby! Talk about a nice truck!!!! DW really liked the backup camera!
We talked a lot about the only offered 3.42 gears in the SRW 3500, maybe RAM will give in on that an allow the 3.73 at least.
So I am ready, but wallet is not, DRATS! Did I say I really liked it? I really liked it!!!
Off to buy a lotto ticket.
Chris
  • I have the 68RFE 6spd auto running 3.42 pulling about 10-11k on the 13 Ram 2500 CTD and I don't notice really any difference between those gears and the 3.73s that I had on my 2012.
    I agree with you that the 13's are nice!
  • There is a current theead running about the weights of those things. Man they are heavy! My dually tips the scales ready to go right at 8000 pounds but the new ones are about 1200 pounds more. Thats crazy. Oh and my 4.10 rear end equipped sure does pull nice. And the fuel economy is every bit as good as the new ones with 3.42 gears.
  • Old-Biscuit wrote:
    Well after that "extended 30 hour test drive", you and Aldo should be pretty good buds!
    If not mistaken.......you do not need 3:73's.
    With that Aisin tranny all you need are those 3:42's
    OK, so it was only 30 minutes, my bad!!
    30 hours and it would be parked at home tonight!!!
    Regarding the gears. Both the RAM and Aisin trannies are double overdrive units and do not need the tall gears to cruise on the freeway at low RPM, so give us a choice like the duallies have, 3.42, 3.73 or 4.10's.
    Their logic is reversed.
    Aisin Seiki Six-Speed AS68RC (Dodge Cab and Chassis Only)
    Specifications:
    First gear: 3.74 n
    Second gear: 2.00
    Third gear: 1.34 n
    Fourth gear: 1.00
    Fifth gear: 0.77 n
    Sixth gear: 0.63
    Reverse: 3.54
    .63 is a tall overdrive gear. My 47RE is .69!
    Chris
  • Well after that "extended 30 hour test drive", you and Aldo should be pretty good buds!
