Community Alumni
Jan 10, 2017If power mirrors are already there then the swap is pretty simple. You remove 3 nuts, disconnect the connector, connect the new mirror, and tighten it back down. If everything is manual then chances are it's still an easy swap. A lot of the manual trucks came with all of the wiring already in the doors along with the connectors. You just have to buy the switches to control the mirrors. I believe there was a heated option in those trucks. In that case you'd have to buy the heater module in order for it to work.
44,066 PostsLatest Activity: Mar 14, 2015
