CAJW
Sep 04, 2013Explorer
Relating experiences with our 2013 AF996, although it doesn't have the direct air output blocked like the 992 does, we can turn the camper into a meat locker in short order! We've gone from a heat soaked 90+ degrees interior temp (after traveling through the AZ desert at 118 degrees OAT) to a comfortable 75-80 degrees in about 30 minutes. That is an extreme test of the unit as normally when we stop for the night and turn on the A/C we'll be setting it on low or on fan only within about 15-20 minutes. The A/C works very well so I wouldn't be concerned about cooling the cabover. The suggestion regarding a fan is a good one as we often turn off the A/C and use a small oscillating fan to keep the cooled air moving. Hope this helps.
