Searching_Ut
Feb 20, 2016Explorer
tatest wrote:
It should not lock up. The cable does not operate the brakes mechanically, it operates a switch to apply power to the brake magnets. The brakes are then applied by forward wheel motion, as they are when you power the brakes from your brake controller.
When you're using a brake controller, the output current to the brake solenoids is controlled by the controller gain settings, and depending on the controller inertia, time, or even how hard the brakes are being applied. You rarely send a full 12 volts, non pulse modulated. With the breakaway switch a full steady 12vdc is sent from the trailer battery and if the brakes are sufficient to lock the wheels they will.
As for not having a working breakaway system, personally the thought of having a runaway 15,000 lbs mass destruction device isn't appealing to me. I check mine breakaway system regularly, and since I use an Andersen Ball hitch for my 5er I also use safety chains even though they aren't required where I'm generally using the trailer. I've never had a trailer get away in years of towing, but why take the chance.
44,066 PostsLatest Activity: Apr 16, 2026
