- CavemanCharlieExplorer IIII never pull mine. I'm afraid it will not go back in. First, that would ruin my weekend and second, I have 2 batteries that are hard to access. It would take me 10-15 minutes to get the batteries unhooked. No inspection in my area.
- GaryWTExplorer
Gdetrailer wrote:
GaryWT wrote:
Old-Biscuit wrote:
GaryWT wrote:
Have never done it and have never thought of doing it.
Hopefully this thread has made you aware of why it should be tested.
I know my brakes work so pulling the e brake cable will not prove anything as far as I can see.
Your brakes might work.. BUT, the switch may not.
That switch is exposed to a lot of moisture year round and even thought the plunger has a "O" ring to seal the switch temperature changes can DRAW the moisture INTO the switch..
Eventually the switch contacts corrode and when the pin is pulled the corrosion will insulate the contacts or the contacts may not even exist any more.. The result is no break away brakes.
How do I know?
Simple, my first trailer I bought was 20 yrs old.. Never thinking about the break away system I did not check it before taking the trailer for inspection..
The inspection station failed the trailer for a FAULTY break away switch..
I had to buy a new switch, install it then return the trailer to the inspection station and DEMONSTRATE that the break away system now was fixed.
The outside of the switch looked perfectly fine but the inside contacts were gone..
I learned an important lesson that day without causing harm.
Test it and test it regularly..
It is sort of like a smoke detector.. How do you know it is working or will function correctly without testing it now and then?
A number of you had a response to this but will respond under one. In all my years of RVing and being on these many sites, I have never seen this topic discussed. I understand what it is all about but frankly new thought about it or knew anyone did it. Kind of am always careful around the cable as I have the thought that if it was pulled, it might not go back in and thus would not be able to camp. We do not have inspections so it is not an issue. Kind of looked at it like the ebrake in the truck or car, never use it so... This spring I will need to take a look at it and check it out. - GdetrailerExplorer III
cbshoestring wrote:
NanciL wrote:
Brings up the question to me:
What if you are traveling with no trailer battery ?
And second question: what if you disconnect the battery and then pull it? just to make sure it will pull out easily
Jack L
In my state (and others as well) travelling without a charged/functionable battery would be a violation of the law. So, travelling with no trailer battery would not be something a law abiding citizen would wilfully do. A functional brake-a-way includes a means to activate. Since it is activated by battery power, the battery must be installed, charged, etc...
Discounnecting the battery and pulling the pin will tell you very little. Sure, you would know the pin can be pulled, but it would not tell you that the switch is working. Nor would it tell you if the wiring is intact. The battery must be charged/connected when the pin is pulled to ensure that a signal is sent to the brakes, and the brakes engage.
X2!
This HAS been endlessly argued on this forum with folks who feel they are above the law AND nothing will happen to them and not bother to have a battery on board, charged AND connected.
I completely fail to see the reasoning or justification as to why anyone would own AND TOW a travel trailer and NEVER have a battery connected when towing.
Just does not make any sense since you NEED a battery to supply power to the fridge, inside lights, furnace (when stopped or overnighting) AND to supply power to the BREAKAWAY system when towing. - cbshoestringExplorer II
Jack L
Discounnecting the battery and pulling the pin will tell you very little. Sure, you would know the pin can be pulled, but it would not tell you that the switch is working. Nor would it tell you if the wiring is intact. The battery must be charged/connected when the pin is pulled to ensure that a signal is sent to the brakes, and the brakes engage. - Old-BiscuitExplorer III
It will PROVE that the Emergency Brake System works.
When connected to tow vehicle trailer brakes are actuated via tow vehicle brake controller which modulates the voltage sent to activate the trailer brakes.
IF trailer should become disconnected the Emergency Brake System engages the trailer brakes using the trailer battery and applies FULL battery voltage provided the switch works and trailer battery is properly charged (Fed Law requires it to supply full voltage to brakes for at least 15 minutes)
So YES pulling the pin will prove something......that your trailer emergency brake system is fully functioning. - GdetrailerExplorer III
How do I know?
It is sort of like a smoke detector.. How do you know it is working or will function correctly without testing it now and then? - beemerphile1Explorer
How else do you know if the switch and its wiring is good? Maybe the wires are cut or the switch is welded solid with rust? - GaryWTExplorer
I know my brakes work so pulling the e brake cable will not prove anything as far as I can see. - GdetrailerExplorer III
TheWB wrote:
I never have. But I pay the state to test it once a year.
No, you are paying the "state" a TAX which is called an "inspection".
It IS up to YOU to ENSURE ALL of your "load" is 100% PROPERLY "secured" at ALL TIMES.
It IS up to YOU to check ALL lights, Pins, Hitch parts, Tires, BRAKES AND BREAK AWAY EVERYTIME you are going to take your trailer out on PUBLIC ROADS.
It IS ULTIMATELY YOUR RESPONSIBILITY as a licensed driver to check these things and make sure they are in 100% working order..
It IS NOT the inspection stations responsibility once a year to tell you something is wrong.
I ALWAYS 100% of each time I am taking a trailer out on the road to do a walk around check of the lights, spot check the tire conditions, double check my hitch and pins PLUS verify the breakaway WORKS.
SAFETY IS A #1 PRIORITY.
SAFETY IS YOUR RESPONSIBILITY AND NO ONE ELSE'S.. - TheWBExplorerI never have. But I pay the state to test it once a year.
44,056 PostsLatest Activity: Dec 27, 2025
