- nick_mExplorer
Marcela wrote:
I've done it with a rubber mat on top of the duraliner. No problems that I ran across. It is a pita to remove.
Is it worse (to remove) than a hard plastic drop in, and when do you need to remove it? I thought it was a great feature that you could remove it but wasn't aware of cases where you had to. - nick_mExplorer
joerg68 wrote:
The problem with removable drop-in bedliners seems to be that the liner can move around in the bed with the camper loaded (even if it is just a tiny little bit) and any dirt particles that get underneath act like sandpaper. Or so I have heard. Don't have one myself.
Yes - definitely a reason to consider a spray on, but I sometimes haul rocks and wall blocks and want a bit more cushion on the aluminum bed and sidewalls. - ajcal225ExplorerI still have the factory plastic bedliner in my truck. Run it with a thin rubber mat on top.
Been that way for 6 years and 2 campers, no issues.
I keep meaning to remove it and do a spray in liner, but keep not getting around to it. - joerg68Nomad IIIThe problem with removable drop-in bedliners seems to be that the liner can move around in the bed with the camper loaded (even if it is just a tiny little bit) and any dirt particles that get underneath act like sandpaper. Or so I have heard. Don't have one myself.
- MarcelaExplorerI've done it with a rubber mat on top of the duraliner. No problems that I ran across. It is a pita to remove.
44,056 PostsLatest Activity: May 04, 2014
