Bedlam
Sep 21, 2013Moderator
My extended cab short bed is about 1/2' longer than the standard cab long bed. In my case, I suffer from the 25% smaller fuel tank but enjoy the maneuverability of the short truck. When I towed a BP, I had less front swing when getting into tight spots. Now with my TC, I am as long as a crew cab long bed - The length is noticeable, but I still out maneuver the guys that are pushing 25' length.
A longer wheelbase does help in porpoising. I towed the same camper with an extended cab Mazda pickup and Ford Bronco II with much less motion in the lighter Mazda.
I was concerned how much additional leverage my BP would add by using a 2' extension on the hitch. Although I do feel it more when a big rig passes, it has not been enough to cause concern. Porpoising has not been an issue with the extension, but I have upgraded suspension. The other factor to consider is that my TV weight increased due to hauling a TC. It would take more force to my truck around than if it was unloaded...
44,071 PostsLatest Activity: Aug 30, 2026
