RoyB
Oct 12, 2015Explorer II
The Magnetek was bought by Parallax. The 7345 is a 45 amp regulated converter with a fixed 13.5 volt output.
You will need to inspect your battery on a regular bases with this unit to make sure it is not boiling out your battery fluids...
I would plan on replacing it with a moderm SMART MODE Converter/charger unit... IOTA or PROGRESSIVE DYNAMICS are good reliable converter/charger units especially if you plan on adding additional batteries for camping off the power grid...
I would not buy a WFCO COnverter/charger unit as they have a track record of not going into SMART MODE charging when you think they should be...
Contact RANDY at BEST CONVERTERS or get a replacement from AMAZON...
Roy Ken
Roy Ken
44,056 PostsLatest Activity: May 04, 2014
