SidecarFlip's avatar
SidecarFlip
Explorer III
Mar 31, 2017
Does your refrigerator work well or not so good?
Curious.
Seems as though RV builders took a step backwards with ammonia absorbtion refrigerators when they decided to install them is slides and or TC's and delete the roof vent in favor of a lower access panel / vent and an upper vent on the camper wall.
If the unit cannot get rid of the heat from the evaporator (mounted on top of the tube above the boiler), it won't cool efficiently and the same applies to a compressor fridge, if it cannot rid itself of heat it won't cool properly.
You have to have efficient heat transfer from the refrigerator cavity to the evaporator to ambient air or your fridge won't cool properly.
The roof vent is a natural chimney, allowing natural draft (warm air rises) to pull in cool air from the bottom vent and exchange it for hot air coming off the evaporator. Remove the roof vent and you remove the natural draft.
My Palomino pop up has the no roof vent but FR did install one 12 volt fan in the upper vent to suck the hot air out. Problem is, one wasn't enough so I added a second muffin fan (computer fan). That really made the fridge 'come alive'. It works as good as the residential unit in our house now.
  • joeshmoe wrote:
    I might do this:
    Video
    Fridge fan
    Basically what I did but my upper vent is a metal louvered affair so I made a bracket and secured the fans to the inside of the camper wall right in front of the evaporator coil.
    You want to use 'fluid bearing' computer fans because they are completely silent. The fan that FR installed in my unit sounded like a meat grinder...terrible. Most likely the cheapest one they could source.
    I also wired mine to the existing thermostat so they cycled when needed and....
    The fans pull very little power, like a couple milliamps each so battery drain during the night or day should not be an issue.
    Always a bunch on e-bay for sale. Dell City Electronics and Digi Key has them as well.
  • Old-Biscuit wrote:
    RV MFGs took a step backwards when they FAILED TO FOLLOW INSTALLATION INSTRUCTIONS provided by Norcold and Dometic.
    Clearances, airflow, ventilation kits etc.
    IF an absorption fridge is properly installed it WILL function/cool correctly
    Stupid RV MFGs!
    x2
  • RV MFGs took a step backwards when they FAILED TO FOLLOW INSTALLATION INSTRUCTIONS provided by Norcold and Dometic.
    Stupid RV MFGs!
  • My Domestic was fine once I stopped it from blowing out.
  • AF 1150 with the fridge in the slide. Has always cooled very nicely. It does have a fan in it. Almost never comes on in winter but you can hear it run on hot sunny days. That usually isn't a problem as those are days the solar cell makes makes lots of power (unlike most of the winter around here in the Pacific Northwest. We have had something like only 7 days with some sunshine since October - )
  • We wouldn't buy any rv with a Norcold. We had one in our VW Eurovan camper and it cost us $500 a year in maintenance to keep it running. We spend a lot of nights in Yellowstone between May and October, and last year we ran into several people who were experiencing problems with their Norcolds -- seemed to be that they didn't run well at over 5,000 feet. We've never had a single problem with our Dometic.
  • My Norcold in my 2001 camper is fantastic. My Dometic in my older 90s camper was not very good, couldn't keep up very well when warm outside.
  • A camping neighbor mentioned to me that he wasn't aware that his frig in the slide had a vent fan that made dry camping a bit harder on his batteries. He wasn't happy.
