- blangenExplorer"Central Wisconsin" is a little vague for us but googling "Wisconsin Tow Bar Installation" may help. If you find results, someone on the Forum may have advice about who they like or don't like. Again, I'm not familiar with your area but you may have more choices other than "RV repair facilities".
- FiresidersExplorerI know I can 4 wheel tow. But I only have Camping World for the tow bar installation. Does any one know of a good motor home repair facility in central Wisconsin?
- dodge_guyExplorer II
Nick-B wrote:
Transfer case will be damaged if only one axle is spinning. Pretty much true for any 4WD or AWD system.
Yep, T-case was designed to have both driveshafts spinning at the same speed. the only way it could be done is to remove the rear driveshaft! - Nick-BExplorerTransfer case will be damaged if only one axle is spinning. Pretty much true for any 4WD or AWD system.
- lanerdExplorer II
sch911 wrote:
NO Neither the 2WD or 4WD Wrangler can be towed on a dolly. But the 4WD model can be towed 4 wheel down very easily. Why the dolly?
I guess I don't understand. If you can tow a 4WD 4-down very easily....why can't you tow it on a dolly? Doesn't compute!
Ron - sch911ExplorerNO Neither the 2WD or 4WD Wrangler can be towed on a dolly. But the 4WD model can be towed 4 wheel down very easily. Why the dolly?
44,027 PostsLatest Activity: Apr 19, 2019
