augustpilot's avatar
augustpilot
Domestic Frig in New Trailer
Have new trailer with Dometic Frig. Have temp set on med setting, put thermometer in frig, says temp in safe zone, all good BUT cottage cheese and other items are freezing on top shelf. Do you think frig is bad or do I need a fan inside. Thanks
  • Dometic uses a plastic clip on thermostat that attaches to the cooling fins. If this clip comes off of the fins or is not adjusted right your fridge will get too cold. Have you verified that the clip is attached and have you attempted to adjust it by changing its position on the fins?
  • Your fridge is probably OK. Gas refrigerators are different from home refrigerators. Gas refrigerators have no moving parts. Heat is extracted at the top rear of the cabinet (taking away heat makes it cold). The cold air is heavier and falls to the bottom settings up a natural circulation inside the cabinet. If you pack the cabinet solid the air cannot circulate which makes it very cold at the top and warmer at the bottom. Try rearranging the food and don't pack things so tight and you will probably be OK.
  • Or move those items lower in fridge
    Area directly under the fins is the coldest spot.
    Warmest spot is on door
