ESDAExplorerAug 02, 2021Dometic ACI have a newer 2020 domestic A/C, which runs fine. However, the last couple times camping trips, it seems to not start up correctly once in a while. Usually, it runs fine cycling on and off as normal....Show More
pianotunaNomad IIIAug 03, 2021Do check the voltage under load. If it is below 108 then do not run the air conditioner. I recommend a Kill-a-watt meter.
Related ContentDometic AC freezing upDometic AC unitDometic AC compressorBad Dometic ACDometic Servel RGE400 fridge too cold
