alaska_av8r
Sep 17, 2017Explorer
Thank you for the info, I set the fridge to gas, then decided for now to just turn it off while testing. On my panel beside the door I turned off gas and electric for the hot water heater.
The air cond ran for quite a while 30 min, and then tripped the breaker again. That doesn't sound right to me, seems like it should have kept running with no problem, and this is with the thermostat set higher at about 74 deg with ambient at 82 deg.
44,056 PostsLatest Activity: May 04, 2014
