pianotuna
Sep 17, 2017Nomad III
Hi,
Air conditioners can draw a LOT of power. Mine starts out at about 1200 watts @ 115 volts (~10.5 amps) and can go up to 1900 watts @ 113 volts (18.5 amps).
I suspect there is low voltage where you are. That may be corrected by using an autoformer. All an energy management system will do is cut off the power.
alaska_av8r wrote:
The air cond ran for quite a while 30 min, and then tripped the breaker again. That doesn't sound right to me, seems like it should have kept running with no problem, and this is with the thermostat set higher at about 74 deg with ambient at 82 deg.
44,056 PostsLatest Activity: May 04, 2014
