sgacougar's avatar
sgacougar
dometic control comfort remote
Greetings all! I am rookie TT owner. I need some help from seasoned RVers!;-) My problem: I changed the batteries in my dometic remote control thermostat, and now Not all of my icons will appear. I have the owner's guide, but that was no help to me. It worked fine before I changed the batteries.
Thanks for any info.
sgacougar
  • I have no knowledge of your unit but....maybe this would help?
    http://tv.manualsonline.com/manuals/mfg/dometic/remote_comfort_control.html?p=1
  • When replacing batteries.......clock displays 0:00 and has to be set again.
    When pushing 'Set' button for clock IF you happen to also press 'reset' button all settings will be lost and need to be re-entered.
    Have you tried.........reprogramming the remote?
  • I know these are the obvious. Are the new batteries in the right way? Check the voltage of the new batteries to make sure they are good? Have you tried putting the old batteries back in to see if you can get one last gasp from them?
  • Thanks for the response old-biscuit...however, my remote thermostat doesn't have a zone button. OR if it does, it's not labeled. It's even more frustrating that when I try to turn unit on(heat) by pressing the button in ceiling, it still doesn't work. It just blinks red. :-(
  • Have you done a 'system reset'?
    SYSTEM RESET
    Turn the ON/OFF switch to 'OFF' position.
    Simultaneously depress and hold the MODE and ZONE push-buttons while turning the ON/OFF switch to 'ON'.
    FF should appear in the LCD display until the MODE and ZONE push-buttons are released.
