niftypkg's avatar
niftypkg
Dometic cube Frig. Q/A
Model #2190 installed in 1993 Sunlite Pop-up. Worked great then trouble. Flame will not stay on. Possible bad thermocouple?? Will light and stay lit for a while then goes out. What do you think? The thermostat is set Ok but is hard to turn. I am afraid to force and break it. Discussion using the 12v option:I read all the search topics. My 2 cents. It is OK to use the 12v Frig option in lieu of gas for traveling down the road but should switch to gas when stationary, camping, etc. I have generally used gas traveling.
I have seen the results of a frig flame explosion when fueling up. Burned the class A to the wheels. May never happen but... Your input.
  • Just a thought but have you cleaned around the pilot burner itself ?? Could be a dirty orifice or corrosion buildup
