n7bsn
Sep 19, 2014Explorer
hddecker wrote:
Do you have you fan set to auto.
How close is the t-stat to a heat register. The genius that designed our camper decided to put a heat register in the hallway right below the stat. Furnace comes on, blows hot air at the stat it shuts off, the ends of the TT were always cooler than was comfortable. I blocked off the register and now the heat cycles as it should.
Try looking around this site if someone has done the mod you may find it here.
http://www.modmyrv.com/2008/07/14/rv-digital-thermostat
Did you look at the type of thermostat he showed? Unlike conventional RV thermo's there is NO Auto/On (fan) switch, that function is buried in the options.
The conversions you (and others) have posted about using a 6 wire system don't work with a three-wire system.
