path1
Jul 16, 2013Explorer
Yes, depending on the model of thermostat. It could be either a slide arm or a circular "anticipator". Remove cover from the thermostat. Locate adjustment. It should be set around .8. This should give about 2-3 degrees temperature swing. Closer to 1.0 sets the temperature closer to set point.
X2
never thought a little thing would help/be a problem but mine was. Good advice on anticipator. Wish I would of known sooner about ours. We went from chill to way to warm until we adjusted ours.
