JCR-1 wrote:
My dometic frig runs fine in cool/cold weather but when temps get up there is just stays cool. I moved the thermistor sensor inside and exposed more of it to the air but still not great at getting things cold inside especially the freezer.. Any ideas?? I heard an fan helps??
Couple of things.....
First:
The tip (just the tip) of thermistor should protrude from top of clip.
Thermistor senses the FIN temp......not air temp
So slide that thermistor back down into clip
Second:
Moving the thermistor *Up/Cooler----Down/Less Cooler*
That will have a minor overall affect on food compartment temp (4-6*F) and ONLY if your model of Dometic does NOT have an adjustable temp control on upper panel (Auto Temp)
Thirdly:
RV fridges that follow ambient air temps (get substantially warmer) have ventilation issues.
Majority of those issues are due to RV MFG. NOT following Fidge Mfg. installation instructions that define clearances/baffles/lack of dead air space etc for proper draft.
Fans in outside compartment can help.
Baffles......tight clearances etc can help
BUT if RV MFG. had just followed the instructions to begin with most 'lack of cooling issues' wouldn't exist
