- egarantNomadCheck voltages for sure, but it’s your control board, they are ****. I had the same kind of problems. Buy a replacement from Dinasour, they are in Oregon. Fridge works best it ever has.
- mattyjExplorerThank you for your responses, I will definitely check these solutions out!
- jimh406Explorer IIIIf it isn't working on Auto, is the breaker on? As far as working sometimes on LP, does it work if you stay in one place and are you level? Otherwise, it could be blowing out or the propane source might not be very good.
- CA_TravelerExplorer IIICould be low voltage. Load test the RV battery. With solar off and shore power unplugged make sure the battery is being charged from the truck alternator.
