sf3291
Jun 12, 2013Explorer
Paul,
Is this the circuit card you ended up replacing?
ckt card
Tearing in to mine, this is the only card I could find...essentially the terminal board that all of the female spade connectors for power, fan, t-stat, etc connect into.
It is under the black box cover to the left of the compressor in this photo here:
compressor view
I certainly hope that card pictured is the one they are sending me. As you can see mine is also plumbed for a 2 or 3 way fridge and the propane lines make it awful tight to get in there. I ended up having to remove the fridge and set it in the aisle. And as luck would have it...the fridge isn't moving any further without either ripping off the plumbing to the evaporator coils inside the fridge or removing the door frame. Sheesh.
ckt card
compressor view
44,068 PostsLatest Activity: Jun 01, 2026
