DutchmenSport wrote:
crazyro wrote:
So, closer examination of the photo, I think my handle catch is identical to your's.  Did you just drill a small hole into the plastic and then screw into that to add the washers?  And, did you do the same to the bottom catch also? Or is the top sufficient for the washer?
I did the same thing to the bottom. Yes, I drilled a pilot hole (smaller than the screw I've used) and just screwed in the washers. It works well! It would probably work with just top or bottom (as the handle would be pushed up).
