msiminoff
Oct 24, 2014Explorer II
egarant wrote:
I did not do the jumper test at this point. Since it seems to be working Mark, do you think it is still needed?
Nice work Eric! No need for the jumper test at this point.
However, since the switch/fuse/breaker cycling seems to have helped I would suggest that you continue to look for the actual source of the problem… it does appear to be a loose/intermittent connection. Based on what you have told us, I still suspect the problem is within the converter/power-center.
Intermittent electrical issues can be quite challenging to solve (especially over the internet). A few years back I had a similar issue (slide would retract, but not extend) and I ultimately tracked it down to a broken solder joint on the slide control board. Hard to find, but easy to fix. (photos below)
Please keep us posted.
-Mark
44,068 PostsLatest Activity: Jun 01, 2026
