time2roll
Dec 31, 2014Nomad
egarant wrote:
I measured battery voltage at the battery leads on the PD converter. It measures 12.1 vs 12.9 volts that I measure direct to the battery.
When I turn on the heater I measure 10.8 V at the converter and 12.7 V directly to the battery.
Why is the converter 12 V reading so much lower than the reading taken by my inverter and solar charge controller which are wired directly to the batteries?
Easy. Move your voltmeter along the connection between the two. Eventually you will find some point with 12.1 on one side and 12.9 on the other. Tighten, repair, replace, clean, or adjust that component or connection.
44,068 PostsLatest Activity: Jun 01, 2026
