Huntindog
Nov 07, 2016Explorer
Door switch
I have a door going into a bunkhouse that is not visible from where the slide control switches are. On my first day of ownership, I neglected to close that door (it opens IN to the bunkhouse) Natural...
2112 wrote:Huntindog wrote:Are you referring to the rocker switch you press up/down to move the slide in/out? This is typically a low current switch, < 0.5A, wired to a control module that handles the high current.
*snip* All this is about a 12' run from where I gotta fish the wires to the slide control switch, which has 30 amps going thru it. The high amp draw is a primary reason I want to go in the relay direction. *snip*
A relay wouldn't be necessary if the proper normally open, momentary closed door jamb switch is wired in series with this rocker switch.
