bighatnohorse
Jun 24, 2017Explorer II
Door window sealant needed.
For those of you that have replaced the rear door window glass;
What type of sealant did you use for the glass and the exterior door window frame?
I'm changing out the frosted glass for clear glass and Lance used something that looks like it may have double-sided adhesive tape on the interior glass-to-frame.
And the exterior frame-to-door appears to have a bead of sealant caulk.
Both sealants have been fairly easy to remove - a desirable quality if glass replacement is required.
