Mike_Up
Jun 18, 2015Explorer
Most quad bunk models are very large campers with heavy hitch weights. This necessitates a 3/4 ton to a 1 ton truck so that you get the payload you need for a large family and the heavy hitch weight.
A double over a double (none slide model) usually necessitates a 3/4 ton or a 1/2 ton truck with a high payload. With a large family as yours, it would be a crew cab truck so you'd be best off with a F150 w/HD payload package or a 3/4 ton truck.
If you go with a model like mine which is a single over double, you'll get more storage. I didn't want a double over double for 2 reasons. You lose the dresser over the bottom double size bunk and it makes getting into the top bunk very hard for smaller kids since most models don't come with a ladder due to the small entrance opening for the beds.
If you do get a double over double size bunk bed with a superslide, you'll likely get a tall closet/ward for the kids but then you'll definitely need a 3/4 ton to keep from going over your GVWR of your truck.
If you're one of the many with a 1/2 ton truck or SUV with a payload of only 1400 lbs or under, you may have to go with a smaller trailer and use a sofa and/or dinette as the sleeping areas for the kids.
I wouldn't go over GVWR because in an 'emergency' situation, the truck may not be able to handle an emergency maneuver and lose control. That's usually why there are those ratings, for the unforeseen emergency situation.
Good luck on your find.
44,070 PostsLatest Activity: Sep 18, 2026
