BarneyS
May 04, 2018Nomad
Cut a piece of marine or exterior plywood that is thick enough to be at or slightly above the brackets and will fit between the two L brackets. Screw or bolt it down. Then screw or bolt down the propane bracket to the plywood.
Looks like you will have to also move your chain snap-up brackets back a bit. No problem doing that as long as you have almost a vertical pull on the chains.
Barney
Barney
