SoundGuy
May 04, 2018Explorer
Thai wrote:
How are people mounting your double propane brackets? Mine doesn't fit and would rather not try to cut and remove the existing braces.
It would help if you'd list the make, model, year of trailer you have - it just may be that the front set of rails are intended for the battery and the rear set for the tanks. Have you compared the width of each?
That said, my trailer stock came with dual 20 lb propane tanks mounted just aft of the tongue jack - no rails, just the tank plate like you have bolted to the A-frame. I prefer having my tanks sitting at the rear of the A-frame just in front of the body but as in your case the tanks wouldn't fit properly between the rails. Simple solution - a piece of 2" pressure treated wood cut to size and painted with gloss black paint. The wood insert is bolted & screwed to the rails, the tank plate is bolted & screwed to the wood insert, the tanks sit in the plate as they normally would.
