SoundGuy
May 05, 2018Explorer
newman fulltimer wrote:
Take your snap blocks off i bet it will fit then
If by "snap blocks" you mean the weight distribution frame brackets then how is removing them going to help? :h Obviously he needs those brackets in order to mount his WD spring bars and 2) his problem has nothing to do with the brackets but the fact the propane tank tray he purchased is too wide to fit between the brackets that are welded to the trailer's A-frame.
