deltabravo
May 06, 2018Nomad
SoundGuy wrote:
It would help if you'd list the make, model, year of trailer you have - it just may be that the front set of rails are intended for the battery and the rear set for the tanks.
All small trailers that have a single tank, the tank is next to the jack and the battery(ies) are behind it, just like most other travel trailers.
Every single tank TT I've seen has the same problem, the brackets are too close together to get the double tank tray to fit between them.
I used some spacers to raise mine up above the angle iron rails.
